Force9 speed test
kenny
Force9 speed test
I`ve gone to the force9 web site and tried to do the speed test but its
saying 0.0
No I know this is wrong as web speed/email speed is fast but why is it saying 0.0 I`ve followed links to change settings which its does auto` but still the same saying:-
Your current speed is:
0.00kbps
Force9 speed test
Hi bigkenny,
give the speed test at www.adslguide.org a go - the F9 test never seemed to be a reliable one to me.
Hope that helps
Jarv
Testing Testing, Ivan
YEP!! Jarv is right I agree, the F9 tester cannot always be relied upon 100% and yes! sometimes it seems to goes abit dool allie hence the 00kbps results.
**The speed tester as an alternative at ADSLguide seems to be more consistent from my own experience. Also ZDNET also have to go tester too.
http://www.adslguide.org.uk/tools/speedtest.asp
or
http://specials.zdnet.co.uk/misc/band-test/
Ivan
F9 FOL Forum Moderator
F9 Broadband Premier 2MB User
Your Forum Your Voice,Get Involved!
kenny
Force9 speed test
Hi bigkenny,
yes I went to that one (plus others) so I knew my settings etc was ok, just seemed funny why the one from your own broadband supplier was going mad with daft readings.
Thanks though at least I know its nothing my end
[ Moderator's note by Ian (slevgb): fixed quote tags]
kenny
Re: Testing Testing, Ivan
thanks at least I know I`m not doing anything wrong, tried other testers so knew it was running OK.
Force9 speed test
One other thing to note is that for some reason my browser seems to cache part of the results. If i clear the cache then run the speed test it seems to work.
I also remember having similar problem with web browser accelarators.
