Flash to Bang
NormanB
Flash to Bang
Hi
What is the forums experience on the time taken to request the ADSL service from Force 9 to the time they first achieve a connection.
What happens once the ASDL is enabled do you lose dial up? The reason I ask id if problems are experienced RU left with telephone support only?
NormanB
RE: Flash to Bang
> Hi
I believe my elapsed time was about 9 days (something like a year ago).
You can still use dial-up access, using a number on which you pay connection charges.
On occasions, I've used both ADSL and dial-up at the same time when I've wanted to check access to my ADSL set-up from "outside" (by dialling in to a non Force9 ISP and then accessing my ADSL equipment using the public IP address, causing the traffic to take the long route round).
RE: Flash to Bang
> > Hi
Exactly 7 days, although there was a problem with submitting the order to BT so it took 2 x 7 days.
