FAT32 conversion in WinME
Having upgraded to WinME, how do I convert a hard drive to FAT32 without losing data?
RE: FAT32 conversion in WinME
Any number of ways Partion Magic, System Comander. there is atool in ME but you may have to go to ad/remove progs and select windows to add it.
PM is by far the best as you are not restricted to 2 gig partions after you convert so you may want to resize your drive without loosing data
If you dont have PM you can get a copy from
http://www.lunaticsoft.host.sk/start.html
choose hd on the bottom menu.
Thank you for your help. My version of ME does nor include the conversion programme. After a couple of hours searching the net I downloaded a conversion programme and instructions from Microsoft. It only took me another hour to get it to work Roll eyes
