Extra IP Addresses...
Anyone know what the exact score with this is as i reading from the site not that easy to obtain extra ip?
Anyone using more than 1 ip at the moment?
Cheers
i have heard previously that if you have a premier account you can have a block of 4 IP addresses if you can show that you can justify having them and know what you are doing with them.
I'm sure there is a previous post somewhere, but I dont know where I'm afraid!!
Dan
found it here, post by a member of staff....
http://portal.f9.net.uk/central/forums/viewtopic.php?t=5653&start=0
With regards to blocks of four static IP addresses, these should only be on an account that has asked for them. However, there have been a couple of instances in the past where an issue with the system has ment that some Premier accounts have ended up with a block of IP addresses rather than their standard one address.
You can request a block of four by raising a <a href="https://portal.f9.net.uk/my.html?action=tickets">Contact Us</a> Ticket and stating a valid reason for the request. Though I would only suggest doing this if you know what you're doing when it comes to configuring your equipment to make use of the multiple IP addresses.
As for people on the higher price accounts, the options available to these people have been outlined in detail elsewhere on these forums. But it boils down to either staying as they are and getting an upgrade to a faster speed when they become available, or dropping down to a less expensive package.
regards,
Dan
