EasyStart - Spam Filter & Anti-Virus where are they ??
According to the easystart package when I signed up it says spam-filter and anti-virus free, does anyone know where I configure these under my account settings, as I'm unable to find them.
thanks
Mike
I'll second that one. Or is it an automatic thing decided on by F9?
Plusnet Staff
Plusnet Staff
You should be able to configure both the Spam and Anti-Virus options under the Services link on the left hand side of the portal.
You should then have links to the security package where you can configure each component.
The only links I can find there are to purchase the package, none to configure the package.
Mark
i had to contact support and get it added to my account as I noticed I couldn't find anywhere to configure it.
The chap @ support was very helpful and set it all up and ensured I could then see it under my email settings so I could configure it myself.
it should be auttomatically added to your account, but not sure why it isn't
check email settings and if not under there give them a ring.
regards
mike
Thanks Martin, there wasn't a place on the ticket to say it.
Mark
Whilst configuring I notice that the domain is didit.force9.co.uk, will the filtering work if it is just didit.f9.co.uk?
Cheers
Mark
Ianwild
Yes Mark - Both addresses are aliases of each other...
