Does the modem + Force9 work with Linux?
Does the modem Work on a Linux operating System. I have checked the box the modem shipped with and can't find out what make and model the modem is, does anyone know?
RE: Does the modem + Force9 work with Linux?
Do you have the PCI or USB modem?
As I'm not sure, I will presume it is a conexant based modem (At a push you could take the top off and see if you can see the word Conexant printed on any of the visible chips). If so, Linux drivers are available here:
http://www.themad-house.co.uk/conexant/conexant-drivers.html
Otherwise, I suggest you ask in one of the hardware forums at www.adslguide.org.uk.
Regards,
Ian Wild
F9 Customer Support
Or, of course, forget the modem idea altogether and buy an ADSL Router instead.
