Does F9 not support PHP scripting?
CallumW
Hi
I put a test PHP forum on my webspace, but I went to the main page and it appears that I don't have PHP scripting enabled against my webspace.
It only shows the PHP page as plain text rather than it running the scripts and returning the properly built/formatted page
Anyone else had this problem?
1 REPLY
just to check, you have put the php board on your CGI webspace havent you? (ftp://cgi.username.force9.co.uk to upload and http://cgi.username.force9.co.uk to view). The normal webspace is not php enabled.
Hope this helps Smiley
Dan
