Discusssion board?
Discusssion board?
Hi, I'm after adding a message/discussion board to my PlusNet site. Can anyone point me in the right direction to download one that is a)free or shareware and b)works with my PlusNet webspace?
RE: Discusssion board?
PhpBB
> PhpBB
Looks good, thanks!
> PhpBB
Ok, is there anything I need to activate from PlusNet to get this working? I've installed all relevant files and followed instructions for quick setup but the install.php file only displays as a text file! Any ideas??
Cheers!
> > PhpBB
> Cheers!
Daft question - you have put this in the CGI space haven't you? You need your mySQL setup and working? You must also change the permissions on config.php to 777 (remember to change them back when you have finished).
Come on Boro!
http://www.waynessa.co.uk/boro.htm
check the support pages for cgi if you don't know how to do this
