Direct Path?
Direct Path?
Can anyone tell me what the direct path is? I have a CGI app i'm trying to install, but It needs the direct path. Anyone tell me what mine is? My domain is www.mattysworld.co.uk or www.mattysworld.force9.co.uk
Thanks!
RE: Direct Path?
Hi
Your direct path for CGI will be this...
/files/local/home/mattysworld/cgi-bin/
You will prob know this but... just in case your cgi stuff goes on a different server from your html.
eg: http://cgi.mattysworlds/cgi-bin/Huh??.cgi
Use this address to run app.
Good luck
> Thanks!
RE: Direct Path?
oops got the last bit wrong...
should be;
http://cgi.mattysworld.force9.co.uk/cgi-bin/Huh.cgi
> Hi
> Good luck
> > Thanks!
RE: Direct Path?
> Thanks!
Thanks paula.....
Don;t suppose you know about PHP and MySQL as well do you?
RE: Direct Path?
Hi
I've got MySQL working with an online photo album. This uses CGI. If you have any questions about MySQL, i'll try to answer them.
> > Thanks!
> Thanks paula.....
