Converting Audio CD's to MP3's
mikeshe
Can anyone please tell me what I need to enable me to convert a normal audio CD to MP3 format?
Many thanks,
Mike
RE: Converting Audio CD's to MP3's
you need a programme for doing this. I normally use musicmatch for it, they have a free version you can use but there is plenty of others out there. Heres a link for the free or the full version of musicmatch.
http://www.musicmatch.com/download/plus/jukebox_intro.htm?os=pc&BTD=1
Or try one of the download sites hers a link to the cnet one right to some mp3 rippers.
http://download.com.com/2001-2025-0.html?tag=dir
mikeshe
Thanks for your help, I'll give them a try.
Mike
tssk
http://www.dbpoweramp.com/
You might also like to try the above... excellent range of stuff like what you have in mind.
I ended up that impressed, I use nowt else now, even bought full versions of the software.
"If you can't be a good example, then you'll just have to be a horrible warning..." Catherine Aird
Only just seen this post. Try Audio CD MP3 Studio 2000. This is shareware with a jingle inserted in your conversion if you do not pay. However, if you go to http://pcplus.co.uk then go to 'more downloads' followed by searching for 'mp3' you will find a link to download a copy which gives instructions to obtain a key to fully unlock it without jingle. It works for me and it is that magic word FREE.
