Congratulations!!! The fastest speed I have ever had!
I think the change that you made last night has made a whale of a difference. On www.adslguide.org.uk the speedtester. I got the fastest result I have ever had!!! 470K download. Wow!!!!!
I do tweaked my MTU size to: 1458.
excellent!!!!
Greg
RE: Congratulations!!! The fastest speed I have ever had!
450k!
Nice 1!
> Hi,
> excellent!!!!
> Greg
cannylad
What software did you use to tweak the MTU size and where is it?
> Hi,
> excellent!!!!
> Greg
Did it through the registry by adding a HWORD value key called MTU in
MY Computer\HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Tcpip\Parameters\Interfaces
Then the interface you use (look for the one with your IP address in it!).
and modifying the value to the desired MTU as a decimal.
Wouldnt avise it unless you know what your doing tho!
> Hi,
> Thanks
> > Hi,
> > excellent!!!!
> > Greg
You can also get a piece of software to do it for you. See this site:
http://www.dslreports.com/front/drtcp.html
Also suggest running the tweak tester at the top of that page.
cheers,
Greg
> Hi,
> Thanks
> > Hi,
> > excellent!!!!
> > Greg
> Hi there,
> cheers,
> Greg
> I tried that software but it did not pick up my USB modem. I did it manually in the registry though.
> > Hi,
> > Thanks
> > > Hi,
> > > excellent!!!!
> > > Greg
