Check email with mobile phone
How can I retreive my email using my Nokia 6310i mobile phone?
RE: Check email with mobile phone
What are you trying to do? It's quite easy to use the 6310 as a modem and connect to Plus.Net from your PC. Just configure it as a GSM modem, enter the phone number, DNS servers, etc and away you go. (Don't know how this works in Windows. My Mac just found the phone over Bluetooth and I entered the details in the networking dialog.)
If you want to check your email from the 6310 then I'm not sure that that is possible.
--> Stephen
Listen to them? - in which case you need some form of text-to-speech service. You can't do that directly, but you might find a provider that you can register with and enter your plusnet email account details with.
Read them via WAP? - some nifty CGI/php programming should be able to accomplish this. Looks like the new CGI server will have IMAP support built into PHP, so this becomes a lot easier. I wouldn't be surprised if there is not some PHP script for this that you could get of the net somewhere.
Hope that helps.
