Cheap CDR's where tp find....
chino
Yes i am after 100 CDR's or even more...
I found found many places that are cheap but when you add on P+P it works out very expensive...
The only condition is that the CDR's are branded
The cheapest i have found are £22 including P+P (80 min)
can anyone help me find somwhere...
cUnDaLl
1.7 GHz AMD XP, 768MB DDR PC2100 Crucial, 120 GB HD IBM Deskstar
Why do we do it because we can...... Smiley
RE: Cheap CDR's where tp find....
I'm not sure on the prices cos they change quire regularly but..
www.bigpockets.co.uk is extremely cheap for all these kinds of things, very reliable too. Me and my friends have ordered from them many times.
Hope this helps.
Gareth
tssk
> Hope this helps.
> Gareth
You might like to try one I use which is cheap...
http://www.blankdiscshop.co.uk/
Or to go straight to the 80 min ones
http://www.blankdiscshop.co.uk/acatalog/SVP_Communications_80_Minute_Discs_2.html
Personally, I use the Traxdata black bottom discs, more expensive, but I have yet to have a bad one. They are great for audio especially, as they are coated twice for durability. I personally rate these better than TDK etc!
Tel
espresso_mick
http://www.cd-rmedia.co.uk/cgi-bin2/cdrmedia/details.pl?id=data40
£16 for the discs 'DataSafe'
£2 for delivery
I've been using CDR-by-Mail [http://www.cdr-by-mail.co.uk/acatalog/index.html] for the last six months of more. Decent prices, wide range of stock, delivery that is fast enough.
I've had no problems, and have so far bought several lots of 100x80min media, a few 'mini CD's, labels, wallets...
