Changing operator logo on T-Mobile?
Is there any way of changing the operator logo on T-Mobile network? I got a new Nokia 6230 and I have tried everything to change the logo and nothing works.
HMM - I might be able to send your phone a SMS_NOKIA_CLEAN message (operator logo removal), if it works or not, is another matter.
PM me if you want me to try this.
There is plenty of software on the web to do this, the only problem is normally connecting to your phone, since you either need infra-red or a data-cable.
I'm pretty sure I still have the software on my laptop, so I can probably send you a logo via my phone.
LogoManager is one piece of software that does this - as long as you have an infra-red or cable connection.
Thank You Chris, I couldn't remember the name of it lol, that's the one I've got somewhere on my old laptop. I've only kept it, as it's got an infra red port.
Aaron
I've tried virtually everything possible to change the logo. I've got DKU-2 cable to connect the phone to PC and tried Oxygen Phone Manager, Logomanager, MobiMB and none of them can do it. I also tried sending a blank logo and a normal logo but the phone says that it cannot save it.
I have sent the SMS_NOKIA_CLEAN message.
Let me know if it worked.
The logo (blank one) has arrived but when I try to save it then it says 'saving failed' Sad
By the sounds of things, your T-Mobile sim has operator logos locked out them.
They do this by installing there own, then locking it. This means only these is available.
A quick Google suggests it's a lost cause.
