Cannot create Root Web
Help!
I'm using Frontpage XP.
I want to upload a web to http://fp.zensible.plus.com.
When I try to do this I get an error message in Frontpage:
'You cannot create a root web at "http://fp.zensible.plus.com". If there is a server at that location, you may create a subweb by specifying a location such as "http://fp.zensible.plus.com/myweb".
I can create subwebs OK but when I go to http://www.zensible.plus.com all it shows is a list of files?
At the end of the day I don't want to create subwebs. How do I create a proper site at fp.zensible.plus.com (that can be accessed at www.zensible.plus.com) using frontpage.
I know I need an index.htm or index.html file there but how do I achieve this? I tried to send a web to http://fp.zensible.plus.com/index.htm but all this creates is a folder called index.html!
Help!
Robert.
1 REPLY
RE: Cannot create Root Web
I would say this topic is not relevant to this forum. If you wish to discuss any aspect of your PlusNet account I would recommedn that you used the PlusNet forum.
With Regards,
Ian Wild
PlusNet Customer Support
