Can't send files with MSN Messenger
Has anybody had this problem?
I am trying to send pictures or files across to my friend using MSN Messenger while we are chatting.
I have done this before with no problems using Freeserve.
But now that I am on this ADSL with Plus.net I can't send files (but I can receive them OK)
I keep getting an error message stating
" We could not send this file because the connection is blocked. Please contact your network administrator or Internet service provider; they may be able to enable file transfers."
I have phoned the helpline of Plus.net and all they seem to do is advise me to put my pictures on my website so my friend can download them from there.
I find this unaceptable as I transfer files with KAZAA Lite and Direct File sharing with no problems.
Anybody had this problem ? or have any idea's of how to solve it?
I have Zonealarm running, and I have disabled this but it still will not work?
Any suggestions would be most appreciated.
Thank you
Droflas (UK).
RE: Can't send files with MSN Messenger
Hi Colin,
I have recently started to use MSN Messenger.
Initially I had the same problem as yourself, but I soon realised ZoneAlarm was causing the "block". After shutting it down completely I was then able to send files during a chat.
I appreciate that I use a 56K dialup on 0808, but I shouldn't think that's relevant.
Hope that helps you.
Dave W
Are you using a direct adsl modem connection or a routed connection.
If it's a NAT-based router, then Messenger doesn't work with these as it's protocols suck (MS problem).
Otherwise, it could still be Zonealarm as I had no end of problems with it. I've given up and moved to Norton.
> Thank you
> Droflas (UK).
wilinsonbell
> i have sent very large files using msn and i have adsl and had no problem, just to let you know it can be done
Roll eyes:
> Roll eyes:
But has it been done behine a NAT network / firewall?
> > Roll eyes:
I use a software firewall, with ADSL, and quite often use MSN messenger to send files. The only problem I have ever had is with WIndows XP so I dumped it!
