Can't delete files in webspace
Hi, as a new boy to the website game I could do with a little help. I have managed to put some folders/directories in my webspace, they appear empty but I am not able to delete them despite changing permissions etc. The error returned says that they are NOT EMPTY ? I cannot see anything in them...
Confused of K/L
What ftp software are you using? In WSFTP there is a box on the server side directory (under mkdir) which is blank. Place -a in this box and it will show your hidden files.
Regards
Mark
Hello,
If you want or need too change your FTP client software (FTP program) then I can highly recommend the following program.
Its completely freeware (for personal use) and is called CoreFTP you can download a copy for free from the following location (see enclosed link below)
http://www.coreftp.com/
Ivan
Hi, I've been using FTP Commander and as an XP user I can go direct but that doesn't work either. I will now try the two suggestions, thanks for now. HNY all
Many thanks Mark and Ivan. I tried coreftp first and it worked first time. Again thanks for the help, a happy new year to you both.
