CGi Server
CGi Server
Hi
Why is F9 not as Business orientated as other isp’s. I want to run Actinic Catalogue on F9 but I also whish to use my Domain Name, but F9 will only let me use the CGi Server not the standard server because the CGI bin has a different server.
Why
Confussed
CGi Server
I believe, if you request it through Contact us, you can have all your webspace hosted on the CGI machine, and your domain name(s) can be pointed there as well. You will then have just the one server to deal with.
CGi Server
That’s ok but if I have two sites ex www.intersarc.co.uk (set to the cgi server as you suggest) what would happen if I also had www.intersarc.co.uk/private/ would this also point to my cgi server as well or to the homepages server.
I look forward to your reply
Regards
Patrick Kirkland
CGi Server
Yes, they would both relate to the CGI server.
