CGI.pm
CGI.pm
I am having trouble with using param('field') to retrieve form data in a script. I believe this is supposed to return the value of the field name entered as a parameter. When I use it I get all the field values back in a long string, just as if I had submitted the whole form in one go.
Has anybody any idea what I might be doing wrong.
Thanks,
Duncan.
1 REPLY
RE: CGI.pmREPLY Ivan
> Thanks,
> Duncan.
Hi Duncan,
I didn't go down this particular route when using a form mailer. I used the one supplied by force9 (pre-loaded script)and I got it working nicely,it works well. So I cannot answer your specific question but just to let you know that the preloaded mailer script does work well as an alternative.
Ivan
