CGI URL problem
CGI URL problem
Hi - I need a little starter help. I've got a custom cgi script I've edited, activated our CGI space and uploaded it I think.
The instructions from free-online seem a bit contradictory. To upload I've FTPd to http://cgi.free-online.co.uk using my username/password and placed the file in cgi-bin/ - this is as per the FAQ.
However, the email sent to me upon activation has all sorts of different stuff in it...
http://cgi.username.free-online.co.uk
homedirectory /files/home2/username
I'm having difficulty equating these two bits of info - I cannot seem to call the script. Sad
Someone help me with kick-off please!
Ta, Ken.
CGI URL problem
ok, from what i'm gettin from ur post is u've uploaded to cgi.free-online.net and put ur file in the cgi-bin directory?
ur link to ur newly uploaded file would be http://cgi.username.free-online.co.uk/cgi-bin/scriptname.cgi
if it's a php type file, i would ftp in to cgi.free-online.net and create a new directory, then upload ur file into there.
ur link to the newly uploaded file would be http://cgi.username.free-online.co.uk/dirname/scriptname.php
hope this helps
Platty
CGI URL problem
Thanks Platty - to be honest that's the URL I tried but no luck. Also the Free-Online FAQ says that all cgi files should be suffixed .pl - don't know if that makes any difference.
It may be that the script is making assumptions about the location of something called CGI.pm ...
#!/usr/bin/perl -w
use CGI;
Huh
Cheers, Ken.
CGI URL problem
ok not to sure about the perl dir, but u can find it by telneting to the webspace, and typing whereis perl
Platty
CGI URL problem
Thanks again Platty! I'll report my finding in case it's of use to anyone else.
Ken.
