CGI Big Time Problem = Headache
Please email adam@elektronik.co.uk
Hi all,
I'm having real problems trying to install a sript called adtrackz. The
installation is seemingly very simple. I filled it out as much as I can, but
still get an error message from the below extract of the config file. Is the
below correct? And if not, what is? Many many thanks adam
#Enter the required values for each variable below.
#Be careful not to change anything else,
#just what's in between the quotes.
#The server path to the data directory, must end with a /
$datapath = "home/adamb01243/cgi-bin/adtrackz/data/";
#The server path to your home directory, must end with a /
$home = "home/adamb01243/htdocs/";
#full www path to t.cgi
$tcgi = "http://cgi.adamb01243.force9.co.uk/cgi-bin/adtrackz/t.cgi";
#your domain, simply enter it without the www's,
$domain = "elektronik.co.uk";
#enter a password, max 10 characters
$password = "111111111";
1 REPLY
audioc
RE: CGI Big Time Problem = Headache
I am no expert, but look at the $datapath and others- should it not have a "/" at the front?
Regards,
Andy
www.audiclub.co.uk
> Hi all,
