Browser problems
Browser problems
Hi, i have recently been experiencing difficulty browsing with both IE and Firefox, some pages will not load, all i get is a referral to the BT Wholesale page telling me i have an ISP snag or browser snag and to shut the window down!!
Plusnet tell me there is nothing wrong with the line, so it must be a setting on my Router, as the problem occurs throughout my network.
I recently changed from a Dlink 614 to an Edimax 7024WG if that helps.
Regards Richard
Browser problems
Almost certainly a DNS forwarding issue. I assume you're router is supplying the DHCP values.
Try putting F9's DNS anto the DHCP pool config, or even just just into the network properties of the clients.
212.159.13.49
212.159.13.50
Browser problems
Try the following:
1) reboot your router
2) from a DOS shell (Start->Run->CMD) type ipconfig /flushdns
3) Reboot your PC.
I've found that the flush DNS does the trick. Had this problem about 2 weeks ago. Also, you shouldn't normally need to manually set DNS entries, but if it works....great.
See following thread that was posted recently which reports the same problem:
http://portal.f9.net.uk/central/forums/viewtopic.php?t=6250
Browser problems
Hi
YEP!! dynem is right almost certain you have whats called a DIRTY DNS cache or arp cache. This causes this kind of problem. Flushing the DNS cache will or should solve this one. :lol:
Ivan
