Avatar image
Avatar image
A question......where can i get an avatar image from for my profile Huh
Phantom_Flan_Fl
Avatar image
Any picture under 80x80 pixels will do.
Try here or here.
The only thing is you shouldn't link to the avatar direct from the site you take it from. You should upload it to your own webspace. People don't take kindly to you linking from their own site.
Avatar image
You can take one from my site if you want, and upload it to your own. www.radioj.co.uk/avitars (yes i spelled the avatars wrong but don't worry Wink )
espresso_mick
Avatar image
Or you could make your own using whatever images you want and a paint program.
Cool
Avatar image
how would i upload it from your webspace to mine ??
thanks
Andy
Avatar image
thanks
Andy
Andy
If you find a picture that you want to use then right click on it and select the "save picture as" option this will allow you to copy the picture to your own machine.
You can then play about with it if you want using a paint program and finaly using an FTP program upload it to your own web space.
Hope this explains it for you Wink
Phantom_Flan_Fl
Avatar image
As for FTP programs, try Cute FTP or the one I use WS_FTP LE.
Avatar image
test
Avatar image
once i have the pic i want to upload.....how do i do it ?
Avatar image
See the instruction on THIS PAGE on how to use your +net webspace.
Phantom_Flan_Fl
Avatar image
Your image shouldn't have 'htdocs' in your URL.
I did try it without it but it didn't work.
Your Leicester City URL is http://www.thefoxes.plus.com/LCFC.gif which gives you this
Your avatar URL is currently this - http://www.thefoxes.plus.com/htdocs%20fox2.gif
so I just think the location is wrong.
Avatar image
i have now uploaded the pic to mywebspace in ...... /htdocs
what webpath do i enter to enable the avatar to be viewed in my profile ?
thanks
Avatar image
Access your profile from the top of this message board. At the bottom there is an option to "Link to off-site Avatar:" Enter the full URL to your image file, in this case probably "http://www.thefoxes.plus.com/LCFC.gif" and submit. Hey presto, one avatar - although personally not a good image to shout about Wink (good luck in the prem next year though Smiley !)
Avatar image
test
Phantom_Flan_Fl
Avatar image
Not sure what you've done but the whole foxes website has gone now. Cry
