Avatar Discussions
Avatar Discussions
and i got told to change my avatar... :?
Avatar Discussions
Ianwild
Avatar Discussions
Yes, well I understand restricted got told twice in the last 5 minutes :lol:
Ianwild
Avatar Discussions
He He - Someone needs to check their Pms! - I am proud of just how attentive the moderators are!
Avatar Discussions
He has read them but not done anything about them yet Cry
Avatar Discussions
That beta.
had no idea
dont look that big on my screen
Wink
Avatar Discussions
sorry
that better :lol:
Avatar Discussions
Ok the dimensions are now within the limits but you have somehow managed to get the file size to 16,657 which is over 50% over the limit of 10,000
it was only 7,404 before you reduced the picture so whatever you have done has not had the desired effect on file size.
Avatar Discussions
LOL
i am so sorry working on it now
You need a chat chan lol
Avatar Discussions
I have split this from the previous topic, as it was going just way too off topic! The previous thread can be found here.
Thomas
Avatar Discussions
This ok if not u just take it off completely
dont know why size in byte when size decrese in size
understand lol Cheesy
cheers
Avatar Discussions
Its still 12,214 bits which is over the 10,000 bits limit so I don't know what software your using to try and reduce it.
To find the size just right click on the image and from the box that appears select properties.
This will give you all the information about the image i.e. file size and pixel size
Avatar Discussions
Yes I understand what you are saying.
I was using Adobe Photoshop and reduced size to 80 by 60 but the file size increased :?
I also only took ¼ of the pic to help also. Smiley
When saving I saved in Jpeg format at lowest possible quality and it kept saying it would end up like 7k but came out about 12k every time. :?
I Dunno Sad
Stupid Adobe Photoshop :?: Stupid me :?:
Never mind it is fixed now…… Cheesy
Thanks to Mr. S R Muir for his E-mail. :lol:
Cheers :mrgreen:
Thank you all, and sorry for any grievances. Wink
Avatar Discussions
If using the "Web export" function in Adobe Photoshop, make sure you click within the box you are going to export before clicking OK.
