AutoPlay WinXP
kenny
AutoPlay WinXP
I`m using WinXP
I `m using a Fuji camera on a USB connection and it used to load up
automatically the software when I connected the camera up.
The same camera, cable works on a laptop so I know there is no
problem with USB lead and camera & software. Like I said it used to
work, now will not.
When I go into My Computer and click on the camera Icon and select Autoplay
it will do it then load the software but will not do it automatically like it used to do.
Any ideas anyone!?
No changes I can think of I`ve done, still got some free USB ports
4 on rear 2 on front in total 6 (tried taking all out still the same)
I tried rear and front ports still the same. Like I said it used to work so whats up!??
I`ve tried the AutoPlay fix from the Win` web site it says its working all
ok
Auto Play replying, Ivan
Hello Bigkenney,
This problem probably isnt hardware related first of all, in other words you havent done any thing wrong. From my own experience of auto play in XP its not a precise science as it where, sometimes auto play can be abit hit and miss to be honest with you.
Yes! I know it should work every time but experience says this isnt always the case. My diagnosis is that your disk probably contains an auto play file which XP picks up when the disk is put in the drive, and its this file that either the drive nolonger reads or XP isnt picking it up but the end result is the same. i.e. its a software problem, file related NOT your hardware. No! I dont have a fix for you but its NOT serious just very annoying IMO.
Ivan
F9 FOL Forum Moderator
F9 Broadband Premier 2MB User
Your Forum, Make Your Voice Count!
AutoPlay WinXP
Try this
Open My Computer.
Under Devices with Removable Storage, right-click the device you want, such as a digital camera or CD-ROM drive, and then click Properties.
On the AutoPlay tab, click the multimedia content type you want to change.
Under Actions, click the action you want Windows to perform when it detects the media type you selected.
It might just have lost the association, or another app might have nicked off with it Wink
kenny
AutoPlay WinXP
Try this
Open My Computer.
No tried all this first time (and just again) still the same will work ,but no auto
AutoPlay WinXP
Is Shell Hardware Detection started in admin tools/services?
kenny
AutoPlay WinXP
will it seems ok says set for Auto`
