Athlon 1900 config
Athlon 1900 config
Please can anyone give me settings for Athlon 1900 xp? ie fsb, voltage, ratio?
thanks
cant find info from amd, m/b websites or dealer.
RE: Athlon 1900 config
> thanks
http://www.amd.com/us-en/Processors/ProductInformation/0,,30_118_1274_3734^3738,00.html
http://www.amd.com/us-en/assets/content_type/white_papers_and_tech_docs/26485A_AthlXPwp_2-10.pdf
http://www.amd.com/us-en/assets/content_type/white_papers_and_tech_docs/26237.pdf
Those are heavily detailed technical specs - I reckon you should be able to find what you want in there?
> thanks
Depends on your motherboard, most are auto sensing.
But some have onboard jumpers for the FBS 100/133 and 166 mzh, which is doubled for the AMD so 200/266/333. You want 133, 166 is only for the new Barton.
So do your multiplyer from 133 so probably 11.
Voltage at 1.75
Unvalued customer since 2001 funding cheap internet for others / DSL/Fibre house move 24 month regrade from 8th May 2017
