Advice Needed
Advice Needed
Hi i planing on doing an mcse has anyone done one. if yes is it worth it. and what companies are the best for it.
Any info is great
Zak
RE: Advice Needed
What do you hope to get out of it? If you have no experiance then it wont help very much getting a job. It all depends on were you are now and were you want to be. Some firms do like them others want experiance, if you have both then your in.
The are expensive considering it may only last a year.
> Any info is great
> Thanks
> Zak
RE: Advice Needed
I'm in the early stages of starting it. I'm not doing a course, just self learning.
Seems quite boring so far, but should be worth it. He's right in what he says you won't find it of use if you have little experience but if you do then go for it!
Chris
RE: Advice Needed
> Chris
If you are just starting and want to get a low level job in i.t, then i would recommend doing one of the A+ courses, also ECDL for general office tasks (I did mine just for an extra qualification).
But yeah, nothing beats working experience.
RE: Advice Needed
> Chris
RE: Advice Needed
i'm american (and lazy) - what's an mcse please?
