Adobe acrobate reader
Can anyone get on the site
www.adobe.com
or
www.adobe.co.uk
I cannot get onto either, and want to download the free reader, and even other sites such as download.com direct the download back to the site, so still cannot download it, am using both IE and mozilla firefox 1.0
Works here, and isn't slow.
Have you tried a reboot?
Novocastrian
No problem here either. Using Firefox
The download page for the reader is:
http://www.adobe.com/support/downloads/main.html
strange, others I have asked, have had no problems either, not work with reboot as I have been trying a few days, thanks for testing it anyway, appreciated!
Would it be possible to paste a traceroute to the website so we can see where the connection is failing?
certainly, if you can tell me how to do that lol, sorry
See the following tutorial: Servers: Ping & Traceroute then just cut & paste the output to a post.
Microsoft Windows XP [Version 5.1.2600]
(C) Copyright 1985-2001 Microsoft Corp.
C:\Documents and Settings\Rob>tracert www.adobe.com
Tracing route to www.wip3.adobe.com [192.150.18.61]
over a maximum of 30 hops:
1 * * * Request timed out.
2 * * * Request timed out.
3 * * * Request timed out.
4 * * * Request timed out.
5 * * * Request timed out.
6 * * * Request timed out.
7 * * * Request timed out.
8 * * * Request timed out.
thats what I am getting through the dos window,
and this is same for www.plus.net
C:\Documents and Settings\Rob>tracert www.plus.net
Tracing route to portal.plus.net [212.159.8.137]
2 29 ms 27 ms 29 ms lo0.plusnet.pth-ag1.plus.net [195.166.128.11]
3 27 ms 28 ms 30 ms gi1-2.vlan3.pth-gw3.plus.net [212.159.1.2]
4 28 ms 31 ms 27 ms gi4-0-23.pth-gw2.plus.net [195.166.129.219]
5 34 ms 33 ms 33 ms atm0-1-0.ptb-gw1.plus.net [195.166.129.246]
6 33 ms 34 ms 33 ms vlan18.sec.ptb-gw4.plus.net [195.166.129.131]
7 35 ms 34 ms 35 ms if2.ptb-al1.plus.net [195.166.129.39]
8 34 ms 34 ms 35 ms portal.plus.net [212.159.8.137]
That's very strange. You can trace to plusnet but get nothing for adobe.
Do you have a software firewall iinstalled.?If so, try disabling it and try the tracert again.
same thing again pete, thanks for your time on this btw
What software firewall are you using. Some need to be uninstalled before they are deactivated. Just disabling them may not actually do it.
Also what ADSL equipment are you using. If it's a router try rebooting it & the PC.
software is mcafee 2004, router is an origo 4 port 8400, have tried this over a few days, and at night modem is turned off completley,
in the meantime tho, someone uploaded it to yousendit.com for me, so have managed to get the program, this is still a puzzle tho lol!!
