Adobe acrobat info
Patch
Adobe acrobat info
Hiya,
Does anyone know if you can use acrobat 5 to open existing pdf documents and copy and paste different pages together.
I have 4 files, each containing 2 pages of an 8 page document and want to put them all together into one pdf file.
Just wondered if I could do that with Adobe Acrobat!
Any ideas
Patch
RE: Adobe acrobat info
> Hiya,
> Any ideas
> Thanks
> Patch
As long as you have the full version of acrobat and not just the reader, i think you will have no problems doing this.
The wise man mocks the mocked, The mocked man mocks the mocker.....
Hi
Yes but...
> Any ideas
try:
http://www.pdf995.com/
for something very much cheaper that will also do it...
Tim
