Access GURU needed
Access GURU needed
I have a nice technical question for someone - and there may be a free mars bar for the quickest response...
I need to set up a database in access with some fields such as header items on invoices with the company's address or phone number on the top - but i want to be able to change them periodically without having to go and edit all of my reports etc...
Along the same lines i want to have some constants such as labour rate that is a constant but which can be changed periodically (it will be used as a default value on some forms).
I know a fair bit about access already and have made a few decent shop databases in the past with auto reorder etc...
So please help... Chris
1 REPLY
RE: Access GURU needed
mmmmm... Mars Bar....
Surely this is as simple as creating a table holding the firm's name etc. and then having header fields that just extract them? Presumably the invoice has the customer's name on it which you find in a table, well it must be just the same as that.
And the labour rate is just the same - a one-row table holding this rate which you select and use in your calculations just like a constant?
Example:
Table of hours worked called ManHours:
ManNo HoursWorked
1 12.4
2 10.3
3 11
4 1.45
Hourly-rate table called PayRate:
HourlyRate
£5.67
Query to calculate pay:
SELECT ManHours.ManNo,
ManHours.HoursWorked,
[HoursWorked]*[PayRate].[HourlyRate] AS Pay
FROM ManHours, PayRate;
ManNo HoursWorked Pay
1 12.4 70.308
2 10.3 58.401
3 11 62.37
4 1.45 8.2215
Seems to work and is nothing like as clever as your 'auto reorder'... or is there more to it?
(I use Access a lot but 'front-ended' by Delphi or C++ Builder and it is very simple with them but it must be equally easy in pure Access?)
Tim
