ASDL in two rooms without a router
Haven't got a clue if this is possible, hence the post.
I have a PC in the main living room, currently wired up for ASDL. We also have a PC in the spare room I'd like to connect up to ASDL as well.
The obvious route would be either wireless network or wire up a router onto the ASDL modem I already have, but I reckon this would be expensive.
Now the spare room needs a telephone cable wiring, so my thinking can I wire up the spare room with normal telephone cable, add an ASDL filter naturally and then wire up another ASDL modem onto the second PC.
I reckon there shouldn't be an issue providing only one PC is accessing the internet, however does anyone have any experience of "sharing" an ASDL connection in this way.
I don't need the two PCs to communicate just use the same telephone wire [in tandem if possible].
Has anyone tried this/got it working?
Thanks in advance,
Franz.
Just Share?
I'm all in favour of keeping such situations as simple as possible. Yes! as far as I can see you have already thought through the two most logical answers to the situation.
But are you aware? that in windows2000 & WinXP you can now share x1 internet connection and this seems to me the obvious answer to your dilemma. One machine takes the role as a server & the other second system becomes a client.
**Yes! you could definately go wireless but then it gets pricey because you would have to have a wireless access point. However now a days you can buy a single product that gives access to the internet to several systems in one device. The only problem is the complexity of the set-up this involves and it does require a good knoweledge of networking & TCP/IP & IP addressing, not to mention the security aspects. So it can get rather difficult & complex be warned its not simple & straight forwards as an option. But I dont want to put you off but just be aware of what your getting into thats all really.
Best Regards Ivan
Technically Yes, but you'd need to keep uplugging the ADSL modems, so is a bit of a bore.
You could look at the cheap networking options that use your existing telephone extension cables using Home Phone Networking. BT's Home Networking is a good example and has been reviewed on ADSL Guide.
Other suppliers (Dabs et al) can provide more basic USB or PCI card HomePNA adaptors for using Win 98/XP Internet Connection Sharing features if you want.
The main advantage to Home Phone Networking is the use of your existing phone extension wiring. This is however at a slower speed than and incompatable with ethernet networks (but more than fast enough for internet sharing).
Regards
Neil
Thanks for the suggestions guys. The BTHome Networking option sounds ideal on the face, but at £200 I think it would be better to spend on doing the correct solution of networking the two computers using cat5 cable and wiring a phone extension cable at the same time.
>But are you aware? that in windows2000 & WinXP you can now share x1 >internet connection and this seems to me the obvious answer to your >dilemma. One machine takes the role as a server & the other second system >becomes a client.
This is a possible route, but would still mean wiring some cat5 cable and it would also mean having both computers on for the client to access, which I wanted to avoid.
>HomePNA adaptors
Not heard of these, looks like I'll have to do some more research. Sad
Thanks for the suggestions guys, gives a few more avenues to investigate.
I'm a great fan of the Draytek Kit, You should be able to get a 2600WE and a wireless card for only a little more than the BT Kit. This is a great bit ' kit. 10/100 ethernet switch and Wireless, built in router, Firewall, VPN etc....
Go on, do it properly, you know you want to :twisted:
i have an external router (smc barricade) connected to via cat 5 cable to a small cheap d link hub this has 4 ports which i then have connected to three sometimes four pcs around the house/workshop, some running win98 some xp. the beauty of this is that not only can any pc connect to the internet but that data can be shared among pcs and is a quick and easy backup system storing data from one pc onto another,network cards cost £5 s/h from computer fairs, cable next to nothing and the hub was less than £20, which for up to 4 pcs is not bad
