ADSL modem crashes my computer....
hi
i recently had adsl installed and since having my USB modem installed my computer crashes when i try to play games, and when i surf web pages, it has only started happening since havin adsl installed
any ideas wot it might be?
cheers
JAy
1 REPLY
Ianwild
Can you tell us what type of motherboard you have? This type of problem can be caused by an underpowered USB Bus.
The normal solutions are to purchase either a powered USB Hub or PCI USB Card, or ideally to change your ADSL equipment and use an ADSL router, which runs independantly from your PC and as such will not impact on the performance of your machine.
Regards,
