ADSL for Mac
ADSL for Mac
Does anyone know the correct settings for the Mac? For example on the TCP-IP Control Panel (MacOS 9) I think it is DHRC Server...
1 REPLY
RE: ADSL for Mac
Hi
it should be easy you need to know first if you are using a nat or a no-nat connection and the ip addresses that you have been assigned
if you can post these details and i will send u the setup details
Darren H
