ADSL Probs
ADSL Probs
I recently istalled ADSL. I get on fine in XP. On my 98SE partition, I cannot get to open any web pages. ASame thing on W2K Pro. It seems to connect fine but there is no data flow. Can anyone help
[Moderators note (by Thomas): Odd bold tag removed for you.]
ADSL Probs
What kind of ADSL equipment are you using -- a router or a modem? (USB? PCI?). Do you have up-to-date drivers installed on the 98SE and W2K platforms (and appropriate service packs)?
ADSL Probs
What kind of ADSL equipment are you using -- a router or a modem? (USB? PCI?). +++++++++++++
Binatone ADSL500 USB Modem
Yes
ADSL Probs
What are your TCP/IP settings on the W2K and 98SE systems?
With the modem powered up, connected and "dialled in":
  • On W2K, enter ipconfig /all at a command prompt. Compare the output with the same on the XP system.
  • On 98SE, enter winipcfg at a command prompt.
In each case, the important things to look out for will be the default route and DNS settings.
