ADSL Download speed
ADSL Download speed
Hi I have a 2MB ADSL connection and since I have made the change to 2MB I am getting really slow download speeds infact I am downloading a 10MB file and I am getting 10Kb\sec not much quicker that my dial up modem 5.5Kb\sec
Has anybody else had the same I know I have run all new cables and now and then I will get 150Kb\sec which is more of what I was expecting I would not have though the contention would be that high to cause this everybody else I speak to has never had their downloads drop this low??
Any help would be great.
Unthrottled or NOT? Ivan
Hello,
Since you upgraded to the 2MB service can I just check with you, have you had your service unthrottled by F9 support?? otherwise you wont get the full 2MB service. If you havent had the connection unthrottled since the upgrade then you need to contact customer support and explain the situation to them and ask them if they would unthrottle your connection which usually be done quite quickly.
**Have you tried optimsing your ADSL connection by tweaking your MTU values? this can improve performace noticably.
Ivan
Re: Unthrottled or NOT? Ivan
Ivan
^ Where can I find some professional/official information on doing this, please?
ADSL Download speed
ya i would like to know that too the mtu for f9 that is
ADSL Download speed
Try this programme: http://www.speedguide.net/downloads.php
Worked for me.
Regards
Mark
ADSL Download speed
I've used the program and nothing noticeable has happened =(
Cheers for the info though didit
ADSL Download speed
Presumably your router already has the optimum settings, I know it "tweaked" mine when I used it.
Just out of curiosity, are you on Premier or Plus? If Plus, could it be the file is through a P2P application which is heavily throttled on this account.?
Regards
Mark
ADSL Download speed
Mark,
Nah, I'm on the residential 2MB premier account and the file was off a website (YouSendIt, RapidShare or File Front I thnk). Either way, they were going no faster than 60-70kB/s
Rich
