35mm slides converted to digital images
Im looking for a reliable and in-expensive means of converting my families 35mm slides to digital images on a CD. Can anyone recommend a service?
Many Thanks
You can buy scanners that will convert the slides to images so you could do it yourself. These can either be stand-a-lone ones or adapters for flatbed scanners
They are expensive though but if you have a lot of slides it may be worth the investment. Try searching for 35mm scanners on google and various other places.
[append]
Maybe this: Canon 8400f Film Scanner 3200x6400dpi may do the trick. I'm sure there are others.
LiamM
I have an Epson Perfection Photo 2480. Link at ebuyer.com. Found it to be very reliable and produces images of very good quality. Also, a bargain at only £65.99 in my opinion.
holdtight
I also use the epson perfection and i cant fault it either, really good results
and fast too
lucky enough to get it for £29.99 ( ex display ) but as new Cheesy
