2nd domain problem.
2nd domain problem.
Hi
My main domain www.thestottfamily.co.uk will allow me to install punbb script.
When i try to run the same script on my 2nd domain www.seroxatmad.co.uk instead of the script running i get a save/load/cancel alert box up!
Any ideas?
Regards
John Stott
P.S I even have my 1st domain pointing to the CGI server and it works fine...i.e www.thestottfamily.co.uk points to cgi......and thestottfamily.co.uk (without the w's) points to the HTDOCS area.
2nd domain problem.
http://www.seroxatmad.co.uk/ points to the homepages server, so can't run CGI Scripts...
2nd domain problem.
Hi
So it cant even run a .php extension...
I was sure it did before becuase i swapped the DNS because i ran a CGI script before and am sure PHP programs were ok.
Can I point the domain to a directory on the CGI server then as i do with the htdocs area?
Regards
Stottie
2nd domain problem.
Not natively, no. Theres a sort of hacky workaround in this thread though.
