24/7 Mgmt - Dial Up Speeds??
Hi all, I've been a bad boy and downloaded to much! and now been placed on 24/7 mgmt.
My problem :- Since 24/7 mgmt has been in place I have been unable to access web pages, read emails etc etc ;-( .... Now according to the Tech support I should only be receiving Dial Up speeds of 67kbps but looking at the AUP/TC it says I should get 67Kbps. Now I thought that 67Kbps was 1/2 meg line? Or am i calculating my speeds wrong?
Can someone shed some light on what speeds I should be browsing at!!!?
Cheers in advance
Dave.
wooooah! inundated with replies TA!
Did you get your 24/7 management lifted? I understand that if you promise F9 to be good, they will lift it.
The new peak time tier system should make it harder to exceed the limits in future as it will regulate your peak time connection and place you in slower catagories as your download amount increases.
