[RESOLVED] - Usertools gateway checker
Fixes: 70
Doesn't work:
[quote author="Usertools Gateway Checker"]Sorry, records show your IP address is not from the Plusnet brand and as such, we cannot detect your gateway.
Almost certainly caused by the reverse traceroute not making it back to the edge router/gateway:
traceroute to 83.216.130.1 (83.216.130.1), 30 hops max, 60 byte packets
1 gw1-g-vlan201.dca.giganews.com (216.196.98.4) 0 ms 0 ms 0 ms
2 te0-7-0-9.mpd22.iad02.atlas.cogentco.com (38.122.62.193) 0 ms te0-0-0-7.mpd22.iad02.atlas.cogentco.com (38.122.67.49) 0 ms 0 ms
3 te0-2-0-4.ccr22.iad02.atlas.cogentco.com (154.54.31.121) 0 ms 0 ms te0-1-0-4.ccr22.iad02.atlas.cogentco.com (154.54.31.117) 0 ms
4 bt.iad01.atlas.cogentco.com (154.54.11.202) 0 ms 0 ms 0 ms
5 t2c2-p5-0-0.uk-eal.eu.bt.net (166.49.164.73) 77 ms 77 ms 77 ms
6 t2c4-xe-11-1-0.uk-eal.eu.bt.net (166.49.237.38) 77 ms 77 ms 77 ms
7 166-49-168-62.eu.bt.net (166.49.168.62) 77 ms 77 ms 77 ms
8 core2-te0-0-0-3.ealing.ukcore.bt.net (62.6.200.173) 80 ms 80 ms 80 ms
9 peer1-xe3-2-1.telehouse.ukcore.bt.net (109.159.254.209) 78 ms 78 ms 78 ms
10 195.99.126.145 (195.99.126.145) 78 ms 195.99.126.139 (195.99.126.139) 79 ms 79 ms
11 ae2.ptw-cr02.plus.net (195.166.129.5) 79 ms 78 ms ae1.pcl-cr01.plus.net (195.166.129.1) 79 ms
12 ae1.pcl-cr02.plus.net (195.166.129.3) 78 ms 78 ms 78 ms
13 * * *
14 * * *
15 * * *
16 * * *
17 * * *
18 * * *
19 * * *
20 * * *
21 * * *
22 * * *
23 * * Max number of unresponsive hops reached (firewall or filter?)
Plusnet Products Team
Fixes: 44
Re: Usertools gateway checker
Yes, I expected this. From the tracing server's point of view I assume every request would appear to come from the CG-NAT router (contents of $_SERVER['REMOTE_ADDR']).
David
Fixes: 44
To follow up on this, after a slight tweak the gateway checker works on CG-NAT connections, though knowing that you are connected to pcl-ag08 might not be particularly informative. Wink
David
Fixes: 70
Excellent, all looking good from here. I'll mark the topic as resolved.
