IRC
Fixes: 69
IRC
I don't seem to be able to connect to IRC servers:
[INFO]	Attempting to connect to “usertools.plus.net”. Use /cancel to abort.
[INFO] Connecting to irc://usertools.plus.net/ (irc://usertools.plus.net/)… [Cancel]
[ERROR] Connection to irc://usertools.plus.net/ (irc://usertools.plus.net/) refused. [Help] Reconnecting in 15 seconds. [Cancel]
[INFO]	Attempting to connect to “efnet”. Use /cancel to abort.
[INFO] Connecting to irc://efnet/ (irc://irc.prison.net/)… [Cancel]
[ERROR] Connection to irc://efnet/ (irc://irc.prison.net/) refused. [Help] Reconnecting in 15 seconds. [Cancel]
Plusnet Products Team
Fixes: 57
Re: IRC
Bob,
Are they on the same internal network as this forum - see my other thread
Fixes: 117
Re: IRC
The PN one could be because your IP address isn't recognised as a PN one and refused.
Will Moderate For Thanks
Fixes: 69
Re: IRC
Quote from: Oldjim
I can't connect to *any* IRC servers, not just the PN one. We think it's something to do with a missing ALG. There's not IRC ALG in the standard list of Juniper ALGs that we can turn
on though. We're going to refer it to out suppliers and see what they say.
Quote from: dvorak
That's probably not helping either.
Fixes: 43
Re: IRC
If I remember correctly the Plusnet IP list is compiled into the usertools IRC client and is somewhat behind even the current list of IPs. Third Party clients wouldn't be affected by that, of course.
David
Re: IRC
I thought the usertools IP list was kept server side, not just from the web client.
F9 member since 4 Sep 1999
F9 ADSL customer since 27 Aug 2004
DLM manages your line the same way DRM manages your rights.
Look at all the pretty graphs! (now with uptime logging!)
Fixes: 117
Re: IRC
Think he means 3rd party IRC servers, not 3rd party clients connecting to usertools IRC.
Well I hope so at any rate Wink
Fixes: 43
Re: IRC
Yes, everything is server side, but on reflection I think I had something different in mind anyway. Embarrassed
David
csogilvie
Re: IRC
The IP list for IRC is in the Firewall... that would be a job for Operations of it needs adjusted.
Plusnet Staff
Plusnet Staff
Re: IRC
Connected fine to the A&A IRC channel using Adium and another using Colloquy so seems fine for me.
VileReynard
Seasoned Pro
Fixes: 9
Re: IRC
So far so good - except!
Bit Torrent is not realistically working.
