slow speeds
- Business
- slow speeds
slow speeds
19-06-2008 4:22 PM
Today 10:34 133 kbps (16.6kB/s) 84 kbps (10.5kB/s)
been told by plus.net that its effectin a few hundred customers, well i'm hopin it gets fixed soon or i b lookin 4 a new isp.
Re: slow speeds
19-06-2008 4:31 PM
Re: slow speeds
19-06-2008 4:41 PM
Quote been told by plus.net that its effectin a few hundred customers
That's the first I've heard of it, I'm assuming that the agent has got the wrong end of the stick.
*update*
I've just spoken to the agents in question and yes, you are affected by a problem which means your profile on our system will show as 'Not Set' or similar. I've produced a cunning workaround to update this and your profile on our side matches the BT one. Can you reboot your modem/router and try a speed test.
Re: slow speeds
19-06-2008 4:49 PM
Re: slow speeds
19-06-2008 4:52 PM
DSL Modulation Mode: MultiMode
DSL Path Mode: Interleaved
Downstream Rate: 4096 kbps
Upstream Rate: 448 kbps
Downstream Margin: 12 db
Upstream Margin: 23 db
Downstream Line Attenuation: 51 db
Upstream Line Attenuation: 15.5 db
Downstream Transmit Power: 12 db
Upstream Transmit Power: 19 db
Cisco Logo
PVC Connection
Encapsulation: RFC 2364 PPPoA
Multiplexing: VC
Qos: UBR
Pcr Rate: 0
Scr Rate: 0
Autodetect: Enable
VPI: 0
VCI: 38
Enable: Yes
PVC Status: Up
lastest speed test is
Today 16:50 145 kbps (18.1kB/s) 82 kbps (10.3kB/s)
Re: slow speeds
19-06-2008 5:03 PM
The next thing I'd like to try is a dialtest from here, if you could reply to the ticket with a 30 minute window when you'll be able to disconnect your router I'll arrange for this to be done. We can then speedtest on your account from here and try to pin down the issue.
Re: slow speeds
19-06-2008 5:07 PM
Re: slow speeds
19-06-2008 5:07 PM
Re: slow speeds
19-06-2008 5:09 PM
Daniel Simmons
Re: slow speeds
19-06-2008 5:20 PM
Re: slow speeds
19-06-2008 5:38 PM
Re: slow speeds
28-08-2008 4:14 PM
The last test i did gave me these results: 656 kbps (82kB/s) 55 kbps (6.88kB/s)
Which after being forced to cope with around 256kpbs connection for the last 3 years is really annoying!! *please upgrade my phoneline.
Can you please try the same speed test on my line.
Thanks in advance.
P.s i forgot to put it took me 23 Seconds to load the plus.net homepage!
and 17 seconds to load this post!!!!
Re: slow speeds
28-08-2008 5:05 PM
Part of the reality is that you are a very long way from your exchange. The highest downstream attenuation that routers report, is 63.5dB, and that's exactly what yours is, showing that you're a long way from the exchange itself.
Your connection profile is currently set to 1000Kbps. Can you try rebooting your router and seeing if you notice an improvement in speed?
Re: slow speeds
28-08-2008 5:21 PM
is there not anything else we can do to make our connection faster?
Ive just run Speedtest.net again and got these results:
683kpbs Download 38kpbs upload - My upload speed has never ever been that low.
Re: slow speeds
28-08-2008 5:27 PM
Just as a precaution, I'd try changing your filters, making sure that you are connecting directly to the master socketvia a filter and try using a different router if at all possible.
If you see that after that that you are seeing a lower downstream attenuation, then we have a result.
