"Im on the road to sloware!"
atbs1
Please see the picture of the graph - my connection used to be around 6 meg but has been steadily deteriorating.  We have the same filter, router and cabling. Nothing has changed and nothing has been added.  after the re-booting of the router at 1225  the speed dropped to 335!.
5 REPLIES 5
pjmarsh
Fixes: 19
Re: "Im on the road to sloware!"
Filters, routers and cabling can break or deteriorate, so it could still be them.  You best be is to try a new filter in the test socket (behind your master socket) and see what effect this has on your sync speed.  If that still doesn't help try a different router to see if that helps.  If it not any of that you will need to raise a fault with Plusnet at http://faults.plus.net who will ask you to do all of the above, and will then raise it with BT if needed.
If it turns out to be a problem with your equipment (filters, routers, internal wiring), then BT have quite a heafty charge (about £125 I think), but doing the above tests will rule out all of that.
Phil
prichardson
Can you retry now after a reconnect.
I have corrected the profile account your account.
No default profile existed on your service, which meant there was no value to change.
I have corrected this now and any future changes will reflect automatically.
atbs1
Thanks P. Richardson.  Speed up to 5503 now.
atbs1
Interesting, speed is now 4702...  still quite a variation - I wonder why.
atbs1
Just re-tested:  5743
