dslam issue?
- Business
- Re: dslam issue?
- « Previous
- 1
- 2
- Next »
Re: dslam issue?
12-02-2021 10:15 AM
@MisterW there's a bug in the business account member area with the configure static ip option too, says not available on my account and account needs upgrading. but business accounts get them free so that must be a bug.
i also would like the reverse dns to be my company name not dyn.plus.net, once i know static ip address i can setup up the forward.
Re: dslam issue?
12-02-2021 10:24 AM
Hi @futurenet, thanks for getting back to me and I'm glad to hear the upload change has gone through fine. I've placed a further modify order to get you provisioned on 80/20 and this again should complete over night for us. As both your download and upload speed look to be just under the current 40/10 however I'm not sure we'll see any change moving forwards. I've also added a static IP to your account and if you turn the router off and back on your side this should show your side too.
I hope this helps and if there's anything further we can assist you with please don't hesitate getting back in touch.
Re: dslam issue?
12-02-2021 10:25 AM - edited 12-02-2021 10:26 AM
@futurenet the fact that the rDNS is showing a dyn.plus.net means that you haven't got a static IP. By default, the rDNS for a static IP will be <accountname>.plus.com. On a business account you can request it be set to a domain name or anonomised to <ip_address>.plus.com.
Sounds like the Business account member centre is no different to the residential one!
edit: looks like Ben was too quick for my reply😀
Re: dslam issue?
12-02-2021 10:28 AM - edited 12-02-2021 10:44 AM
Re: dslam issue?
12-02-2021 11:09 AM
Hi @futurenet, thanks for getting back to me. I've replied to the ticket on your account regarding setting up reverseDNS and the ticket can be seen here.
Re: dslam issue?
12-02-2021 1:53 PM - edited 12-02-2021 1:53 PM
@BD replied back, thanks again for your help
Re: dslam issue?
13-02-2021 8:38 AM - edited 13-02-2021 8:40 AM
the profile didnt get update @BD
still not provisioned correctly , business should be 80/20
Receive direction | Send direction | ||
Max. DSLAM throughput | kbit/s | 40000 | 10000 |
Min. DSLAM throughput | kbit/s | 128 | |
Attainable throughput | kbit/s | 43484 | 6209 |
Current throughput | kbit/s | 39232 | 6209 |
Min. effective data rate | kbit/s | 29747 | |
Seamless rate adaptation | off | off |
Re: dslam issue?
15-02-2021 10:11 AM
all good, looks like it updated this morning some time. held back by line length (which is annoying as theres a box right near us (30m away) too, but were conected to the one 950m away.
getting a whole extra 3-4 mbit on 80 profile lol
Negotiated Connection Properties
Max. DSLAM throughput | kbit/s | 80000 | 20000 |
Attainable throughput | kbit/s | 44533 | 6313 |
Current throughput | kbit/s | 43168 | 6312 |
Min. effective data rate | kbit/s | 39600 | |
Seamless rate adaptation | off | off | |
Latency | fast | fast | |
Impulse Noise Protection (INP) | 44 | 0 | |
G.INP | on | off | |
Signal-to-noise ratio | dB | 8 | 6 |
Re: dslam issue?
15-02-2021 10:38 AM
Thanks for getting back to me @futurenet. I've looked into this for you and have updated the ticket on your account I'm personally monitoring for you with my findings and what should happen from here in regards to your speeds.The ticket I'm monitoring on your account can be seen here.
Re: dslam issue?
15-02-2021 11:15 AM
i think speed is probably max because of line length to be honest, been trying to get openreach to connect the remaining 20 or so properties they left out to the newer closer cabinet is proving to be a pain, as our speeds would max then.
Re: dslam issue?
15-02-2021 11:49 AM
It very well could be the case however as I can currently see there's a banding showing on your connection when testing I've still requested this be removed which hopefully we should see over the coming days. Not only that but it seems very coincidental for your speeds to top out at a perfect 40Mbps so I suspect the banding being removed may see this creep up slightly further As mentioned, I'll be monitoring this further for you and be back in otuch once I can see the banding is removed.
- « Previous
- 1
- 2
- Next »
