difference between business FTTC and home?
- Business
- difference between business FTTC and home?
13-06-2013 7:51 PM
Are there any ping graphs available for business lines, interested to see if they don't exhibit the evening peak time ping hump. If they didn't I'd be interested in taking a business connection.
Re: difference between business FTTC and home?
14-06-2013 7:58 AM
14-06-2013 11:02 AM
26-06-2013 10:46 AM
27-06-2013 7:52 AM
28-06-2013 12:07 PM
How does general performance/usage seem for you?
28-06-2013 12:26 PM
I could be wrong but I don't think an optimistic Plusnet profile helps with the packet loss.
28-06-2013 1:47 PM
Thanks for your concern, our connection was only installed on the 26 June, and is not currently being used, I also haven't had chance to unlock the modem (it's a HG612)
I think whats happening is that we have a lot of errors on the line, and I was fully expecting to to see an increase in the ping times Thursday morning, meaning inter leaving has been applied.
It looks like it might have been applied just before 4am this morning, but the ping has not increased (which it usually does with interleaving). The packet loss has decreased though, so I expect more interleaving to be applied to correct the errors.
I also wonder if we are on an 40/10 package instead of the 80/20 package which we should be on, once I unlock the modem I'll know more. Our PlusNet profile is 37Mb, I'm wondering if we have a much higher attainable than 40, and this is why the ping hasn't increased as our speed has stayed the same - I can't run speed tests via the wireless as it's installed the other end of the building.
We are not using the connection at the moment, we are still on our old ADSL line, I can connect to it via wireless but no one else has the code. Once I'm satisfied the connection is stable I'll get our network switched over to use the new connection.
I've just run a BT Diagnostics speed test (speeds a meaning less as it was by a very poor wifi connection), and it confirms we are on a 40/10 profile:
DS IP Profile for our line is 38.71Mbps
US IP Profile for our line is 10Mbps
I won't push to be put on an 80/20 package until I've confirmed attainable rates, no point if it's not much more.
28-06-2013 1:52 PM
@Jimbof - sorry to take your thread off-course.
30-06-2013 5:05 PM
Quote from: w23 @Jimbof - sorry to take your thread off-course.
Although we've taken his thread of course, it does actually quite clearly answer his question, the graphs quite clearly show the evening ping peak hump.
Anyway looks like interleaving increased this morning, and now the lost packets appear to be gone, apart from one spike.
30-06-2013 8:20 PM
I must say I see no ill-effect from the hump, but it is interesting it is still there.
- Business
