Wi-Fi Disconnections and Firewall ICMP Check
LynnpinABS
I have recently noticed wi-fi disconnections occurring several times a day which I thought was maybe a poor wi-fi signal to my computer but on checking the event log it appears that I have actually been disconnected.  Am I right?  Some of the events at the bottom (last 4 or 5 items) occurred before I was even online in the morning.
Another weird thing that is happening is when I log into the router it says I have the wrong user name or password even though the first time this happened I re-entered it and saved it but next time I tried to log in it again said it was incorrect and I then have to do it manually.  Are the two related are just a coincidence?
Recorded Events
Time Message
Apr 15 13:33:02 LOGIN User admin logged in on [HTTP] (from 192.168.1.80)
Apr 15 13:32:50 LOGIN User admin tried to login on [HTTP] (from 192.168.1.80)
Apr 15 13:32:23 LOGIN User admin tried to login on [HTTP] (from 192.168.1.80)
Apr 15 13:31:51 LOGIN User admin tried to login on [HTTP] (from 192.168.1.80)
Apr 15 13:23:18 SNTP Synchronised to server: 212.159.6.9
Apr 15 12:53:35 LOGIN User admin logged in on [HTTP] (from 192.168.1.80)
Apr 15 12:52:44 LOGIN User admin tried to login on [HTTP] (from 192.168.1.80)
Apr 15 12:52:29 LOGIN User admin tried to login on [HTTP] (from 192.168.1.80)
Apr 15 12:52:23 LOGIN User tried to login on [HTTP] (from 192.168.1.80)
Apr 15 12:52:18 LOGIN User admin tried to login on [HTTP] (from 192.168.1.80)
Apr 15 12:52:05 LOGIN User admin tried to login on [HTTP] (from 192.168.1.80)
Apr 15 12:40:05 FIREWALL icmp check (1 of 1): Protocol: ICMP Src ip: 114.25.89.10 Dst ip: My IP Address Type: Destination Unreachable Code: Port Unreacheable
Apr 15 12:36:15 FIREWALL icmp check (1 of 1): Protocol: ICMP Src ip: 173.226.143.71 Dst ip: My IP Address Type: Destination Unreachable Code: Port Unreacheable
Apr 15 12:23:18 SNTP Synchronised to server: 212.159.6.10
Apr 15 11:23:18 SNTP Synchronised to server: 212.159.6.9
Apr 15 11:18:32 FIREWALL icmp check (1 of 1): Protocol: ICMP Src ip: 83.15.207.57 Dst ip: My IP Address 5 Type: Destination Unreachable Code: Port Unreacheable
Apr 15 10:32:21 FIREWALL icmp check (1 of 1): Protocol: ICMP Src ip: 58.127.112.207 Dst ip: My IP Address Type: Destination Unreachable Code: Port Unreacheable
Apr 15 10:23:18 SNTP Synchronised to server: 212.159.13.50
Apr 15 09:31:31 FIREWALL icmp check (1 of 1): Protocol: ICMP Src ip: 86.111.28.42 Dst ip: My IP Address Type: Destination Unreachable Code: Port Unreacheable
Apr 15 09:23:18 SNTP Synchronised to server: 212.159.6.9
Apr 15 09:18:58 LOGIN User admin tried to login on [HTTP] (from 192.168.1.77)
Apr 15 09:18:40 LOGIN User admin tried to login on [HTTP] (from 192.168.1.77)
Apr 15 09:18:34 LOGIN User admin tried to login on [HTTP] (from 192.168.1.77)
Apr 15 09:18:09 LOGIN wireless station [00:18:de:b5:6f:d5] can't get authorized.
Apr 15 08:36:39 FIREWALL icmp check (1 of 1): Protocol: ICMP Src ip: 70.124.17.67 Dst ip: My IP Address Type: Destination Unreachable Code: Host Unreacheable
Apr 15 08:23:18 SNTP Synchronised again to server: 212.159.13.50
Apr 15 07:23:18 SNTP Synchronised again to server: 212.159.13.50
Apr 15 07:21:29 FIREWALL icmp check (1 of 3): Protocol: ICMP Src ip: 114.43.76.144 Dst ip: My IP Address Type: Destination Unreachable Code: Port Unreacheable
Apr 15 07:19:13 FIREWALL icmp check (1 of 1): Protocol: ICMP Src ip: 198.72.194.73 Dst ip: My IP Address Type: Destination Unreachable Code: Communication Administratively Prohibited
Apr 15 06:23:18 SNTP Synchronised again to server: 212.159.13.50
79 REPLIES 79
Oldjim
Fixes: 63
Re: Wi-Fi Disconnections and Firewall ICMP Check
You have included your IP address - you may want to remove it
The Firewall logs are attempts to get in by a third party and nothing to worry about
They do not have anything to do with the problem you are seeing
Regarding login - which browser are you using
Which router are you using
LynnpinABS
Thanks Jim, I have taken them out.  I think I got them all.  By the way, are you looking younger these days!
The firewall logs seem to occur when I get a notification that I am now connected.  (I'm using XP - yes I know!) and it flags up a notification every time it connects and disconnects.
I'm using Opera browser and the router is a Technicolor TG582N.
So the red exclamation marks I'm getting on the log, are they not actual disconnections, just warnings?
Oldjim
Fixes: 63
That is correct
However there is something wrong as there are numerous failed logins and one wireless failure
Is that one of your devices
The failed logins are not from the same device if there wasn't a loss of connection in between
Have you got several devices connected to the router or was there a loss of connection to the router between them
Were those multiple attempts to login all you
One thing which is concerning is that the IP address of the devices is 1.77 and 1.80 whereas normally the router allocates addresses starting at about 1.67
If you go into the router how many devices are connected - this link should take you to it http://192.168.1.254/cgi/b/devs/ov/?be=0&l0=4&l1=0
LynnpinABS
Thanks for your response Jim.  Yes, the failed logins are all me.  00:18:de:b5:6f:d5 looks like it's my computer.  I don't know why my logins aren't working.  I just deleted the password and saved it again when I was doing the original post so I know it is correct and yet it says it is not recognised, that's why I keep trying to login.  I've got nothing physically connected to the router, everything is wireless, two computers and two printers.
It shows there are 4 devices connected: my computer, 2 printers and one "unknown" but it says it's "inactive".  I think this may be the other computer as it's not switched on today.
Oldjim
Fixes: 63
It does look as the computer is losing the wifi signal
try using inSSIDer to check the channels being used by other networks around you http://www.techspot.com/downloads/5936-inssider.html
LynnpinABS
So Jim do you think I am not actually losing my Plusnet connection, just my wi-fi connection?  The router is only 10 feet away from me.
I've used InSSIDer at home and, to be honest, it is a bit unfathomable to me.  Given that I'm in Newcastle city centre it must be like spaghetti junction so it's going to be even worse.
Could any Plusnet staff check for disconnections for me?
Pettitto
Fixes: 5
Here's your connection graph (Broadband)
<img src="http://community.plus.net/visualradius/generated/image13975789187188.png"/>
It looks as though it could be the Wireless Dropping out. You could try using a different Wireless Channel as per: http://www.plus.net/support/broadband/hardware/technicolor-582n-wireless.shtml
Oldjim
Fixes: 63
Non of the log entries refer to losing the internet connection
LynnpinABS
Thanks Jim and Chris.  I'll have a look tomorrow at changing the channel to see if that makes any difference.  I don't know if this is also happening with the other computer as it's not used online as much but I think I need to check that too.
LynnpinABS
It's me again.  I am definitely losing my connection.  I have just been cut off 3 times and the router "broadband" light was off.  I was on ebay at the time and suddenly my page changed to the Technicolor Gateway page and although my password is saved it said it was incorrect, but that's by the by I think.
The log shows PP Link Up 3 times but no PP Link down which I have had on my home broadband before but as this is a business line I was expecting a more consistent service.
Can anyone throw any light on the subject - it can't be down to wireless use surely if the router is going off and on.  Thanks.
Pettitto
Fixes: 5
Hi LynnpinABS,
I've just checked your connection:
<img src="http://community.plus.net/visualradius/generated/image14017235069381.png"/>
I can see a couple of drops, are these the drops that you've noticed. We can't see any other drops, than those on the graph.
LynnpinABS
According to the event log I have PP Link Up at 15:11:49,  and 16:09:57 and PP Link Down at 16:07:09.
Pettitto
Fixes: 5
That correlates with the above graph.
It seems a little strange that it's been stable for quite some time then for a couple of drops to emerge. Can you let us know if you have further drops?
LynnpinABS
Yes I'll let you know Chris.  The trouble is it's difficult to know when it happens because I wait so long for pages to render normally that by the time I realise it's off it could be back on again. This is the first time I've noticed the router going off and on so I was lucky to catch it.  But I do also have the signal coming up in Windows to say that "you are now connected" several times a day.
