Website being Blocked bu Plusnet
LDWS
Hello - we launched a site on 4th December: https://4love.uk/
We noticed it had been blocked on Plusnet - incorrectly classified, so requested an unblock via blocked.org.uk
We followed this up with 2 separate communications via email to Plusnet to request the re classification of the site. In addition to this the BBFC have also requested on two occasions that the block is lifted.
It is now 27th February and Plusnet is still blocking the website.
Regards
Liam
17 REPLIES 17
Mav
Fixes: 518
Re: Website being Blocked bu Plusnet
Hi @LDWS and welcome to the Plusnet Community Forums.
I have been able to access that site from two different Plusnet accounts.
I've also been able to access from one non-Plusnet account.
Forum Moderator and Customer
Probably irrelevant, but it works on my NON Plusnet account -
Champnet
Fixes: 21
No problems from a Plusnet account…..
LDWS
Thanks for coming back to me.
We’ve had a few customers with a security certificate not trusted. It’s also still showing in blocked.org.uk as having restrictions - so I’m not to sure what the issue is?
iannewson
Fixes: 5
@Mav ahh but do you use Plusnets DNS?
Fixes: 1,495
Suspect it could be being blocked by Safeguard rather than the standard DNS servers.
LDWS
So is that a setting an individual user needs to change? Sorry not too familiar with SafeGuard
Mav
Fixes: 518
No.
Fixes: 250
Users can opt to use or not use SafeGuard: it somewhat looks as though those of us not using SafeGuard can access the site without difficulty.  Where is your intel coming from advising that Plusnet users cannot access the site?  Have you asked if they are using SafeGuard?
AIUI SafeGuard users can whitelist sites.
Champnet
Fixes: 21
I use Plusnet's DNS on a Plusnet account, no problems.
We could really do with some who's using SafeGuard to try to access the site.   Any volunteers ?
pjmarsh
Fixes: 24
@LDWS, zScaler are also blocking you:
I see from blocked.org that CloudFlare Family DNS and EE are both on the list as well.
The zvelo web content categorisation checker is reporting -
Screenshot 2024-02-28 at 08-51-03 Check a URL Category URL Database For DNS & Web Filtering.png
Given the "Safeguard" is intended to allow unsupervised children to safely access the internet on Plusnet connections,
it will probably be the "Pornography" and "Mature Audiences" categorisations that would trigger "Safeguard" blocking ?
Champnet
Fixes: 21
SafeGuard reports :
Fixes: 250
@LDWS
It is apparent that the real issue is the assessment of your site by the big safeguarding providers ... not that (specifically) PlusNet is blocking it.
The domain name is suggestive of something which the site appears not to be - that is probably a key contributor to the issue.  You are going to have to put effort in having the site removed from block lists...
How to Remove Your Site from Google’s Blocklist (jetpack.com)
Website Blocklist Check & Removal | Sucuri
What is URL Blacklist and How to Fix It? (geekflare.com)
In looking for some silver bullet for you, I came across this analysis platform - VirusTotal - Domain - 4love.uk - look at the site content tag!!  I think that points to your issue.
