Voip phone problems with broadband. Keeps dropping out
- Business
- Voip phone problems with broadband. Keeps dropping...
- « Previous
- 1
- 2
- Next »
Re: Voip phone problems with broadband. Keeps dropping out
11-08-2015 11:40 AM
I'm a customer just like you. Once upon a time I could have nudged one of the guys to help, but I no longer work for PN.
M
11-08-2015 11:47 AM
There are a couple of disconnections showing but nothing overly concerning:
I don't suppose you've got a different router you can put your Plusnet connection details in and try have you?
11-08-2015 11:56 AM
Thanks for your reply. Yes when i spoke to john in support yesterday he did mentioned these issues, but my gut feeling is that this isn't the problem. issues are occurring dozens of time a day. Do you know how to apply the below port ranges to the sagemcom, as when i have been in to the settings there is nothing obvious.
5060-5090 UDP
16384-16482 UDP
8000-8200 UDP
20000-65535 UDP
The only other router is a sky one which is at home, I will bring to the office tomorrow and try that.
11-08-2015 12:10 PM
You'll probably need to add new game or application for each range of ports.
11-08-2015 1:24 PM
Yeah im there. So i've clicked the "add new game/application" button and called it Phone. So now i need to select it and assign it to a device from the drop down list. Should my Voip phone be listed in the device drop down menu would you say? As i cannon see it, am i getting this right, do you think?
11-08-2015 1:28 PM
11-08-2015 1:32 PM
If you still have a static IP on the phone form earlier, you might need to set it back to DHCP so that the router see's it.
11-08-2015 1:44 PM
Thanks for the help with this. I now know how to add port ranges, so hurdle over, hopefully the phone will start working properly. Thanks again.
James
11-08-2015 2:07 PM
I wouldn't bank on it I suspect the 2704 was using uPnP to do the required forwarding at times when the phone was working.
Some of the other threads about port forwarding issues with the 2704 might be worth reading:-
http://community.plus.net/forum/index.php/topic,140665.0.html
http://community.plus.net/forum/index.php/topic,140012.0.html
http://community.plus.net/forum/index.php/topic,142246.0.html
http://community.plus.net/forum/index.php/topic,137430.0.html
http://community.plus.net/forum/index.php/topic,139281.0.html
http://community.plus.net/forum/index.php/topic,138463.0.html
11-08-2015 2:21 PM
11-08-2015 2:33 PM
Let's hope so. What have you got to swap it out with ?
Quote Hopefully will make some headway tomorrow when i swap it out
11-08-2015 2:37 PM
14-08-2015 4:02 PM
Just a bit of feed back. It is all pointing to this sagem router. I have had my sky router plugged in all day and have not had one network error message or disconnection. I hope to have a continued uninterrupted service. However this does suggest that the Sagem router is not fit for business purpose? and also leaves me without a router at home. I look forward to plusnets feedback.
Regards
James
14-08-2015 5:19 PM
Thanks for the feedback. There do seem to be quite a few reported problems with this router. This recenet one http://community.plus.net/forum/index.php/topic,142257.0.html is quite interesting. It does seem pretty basic, especially for a business connection!. In my office we're still using the old 2700HGV ( aka BT Business hub ) because it's so stable and just works, plus we have a spare ready configured in case of failure
Quote Just a bit of feed back. It is all pointing to this sagem router.
15-08-2015 7:05 AM
Your business is too important to rely on "free" and that Sagem is simply not suitable for any business customer. Check your budget and get on line and order some proper business grade kit. You'll find the Sagem just fine for sitting on your desk. It makes a reasonable coaster and holds a coffee cup reasonably well.
M
- « Previous
- 1
- 2
- Next »
- Business
