Using business product for open access?
- Business
- Using business product for open access?
16-06-2009 6:46 AM
I don't think there will be enough usage (or available cash) to warrant a leased line, so was wondering if this type of usage was acceptable on a business product?
Re: Using business product for open access?
16-06-2009 9:41 AM
We've got a number of boarding schools that are business customers who use the connection for something similar.
16-06-2009 9:47 AM
We use it at work as an additional measure, and whilst it wouldn't necessarily stop people from abusing the connection, it would make it a little safer from the churches POV.
I'd also be tempted to setup the network to use a modem, hardwired to an access point, rather than a combined device such as one may use at home.
This enables you to ensure that the modem remains on all the time, but you can instruct the people responsible for 'opening up' that they simply need to turn on the power to the AP to allow folks to get access and off again before they leave (stopping overnight use/abuse say) - and of course this approach safeguards sync speed etc a little more robustly.
16-06-2009 9:53 AM
Hadn't thought about separate AP, was looking at something like the Draytek Vigor 2820n which you can have multiples SSID's and also time controlled wireless.
16-06-2009 10:16 AM
Where abouts in Leeds is it? I'm SW of Leeds (Pudsey)
16-06-2009 10:28 AM
16-06-2009 10:47 AM
Leeds Met continue to take over the world!
Should get decent stats there, the three central Leeds BT Exchanges are all located next to the ring road (A58(M)) in an anticlockwise direction. (Grace Street and Hanover Well - which are either side of the ring road where Park Lane crosses it, and Lisbon Street which is just a little further south on the ring road.)
The furthest one is less than a mile away, and the closest much closer.
Fingers crossed hey!
As an aside, isn't there an option to lease a nominal amount of bandwidth from Leeds Met? They have boatloads in the city centre!
16-06-2009 11:29 AM
Quote from: James_G I'd also be tempted to setup the network to use a modem, hardwired to an access point, rather than a combined device such as one may use at home.
Minor nit-pick here. You need a wireless WAN router which accepts a DSL modem on it's WAN port, not an AP. Strictly speaking, an AP is a device which just allows a wireless connection to an existing LAN and doesn't have IP routing or PPP abilities.
Note that the Draytek 2820 series can either use their own inbuilt modem or will accept a separate modem on their WAN ports (probably a good thing as Draytek DSL performance isn't that wonderful). A slightly cheaper route might be a 2910 which is a WAN only device and can be found on Ebay for quite a bit less. Couple that with something like a cheap DG834V4 also from Ebay and you'll have an excellent combination.
Mike
16-06-2009 11:47 AM
16-06-2009 12:04 PM
Mike
16-06-2009 12:10 PM
Quote from: adiewoo In the centre of town, here is a webcam feed for http://160.9.161.231/view/index.shtml
I'm not sure if it's the camera angle or what but that's one ugly looking building
Prince Charles would probably like it tho'
Mike
16-06-2009 12:13 PM
It's very marginal though - I believe they describe this type of architecture as 'polarising'.
- Business
