Upload speed
Stigfish
Upload speed
Can anyone tell me if my upload speed is correct please (i was hoping for alittle faster)
DSL Type: G.992.1 annex A
Bandwidth (Up/Down) [kbps/kbps]: 448 / 8,128
Output Power (Up/Down) [dBm]: 11.5 / 19.5
Line Attenuation (Up/Down) [dB]: 13.0 / 20.0
SN Margin (Up/Down) [dB]: 25.0 / 11.5
Vendor ID (Local/Remote): TMMB / ALCB
My migration to plusnet (business 3) has only happened this morning, so maybe it will take time to increase?
Overall a very pleasant trouble-free migration though  Wink
5 REPLIES 5
Oldjim
Fixes: 63
Re: Upload speed
No it isn't.
But if you were on 448kbps with your previous provider the migration would probably have retained that and it will need a further action from Plusnet to upgrade you.
Stigfish
Re: Upload speed
thanks for your reply Oldjim, yes it was the same with my old provider, do i need to action a ticket or will someone in the know pick this up from here?
thanks again.
prichardson
Re: Upload speed
Indeed, on checking this, this is a result of the type of migration that has been placed.
I have now submitted an order for you to correct this, which will complete overnight tonight. Your upstream should increase to 832kbps based on statistics.
Stigfish
Re: Upload speed
Excellent, thank you very much Phil, greatly appreciated  Wink
Stigfish
Re: Upload speed
Upload speed now at 832, thanks again Phil  Smiley
