Upload speed
- Business
- Re: Upload speed
Upload speed
12-04-2010 3:55 PM
Can anyone tell me if my upload speed is correct please (i was hoping for alittle faster)
DSL Type: G.992.1 annex A
Bandwidth (Up/Down) [kbps/kbps]: 448 / 8,128
Output Power (Up/Down) [dBm]: 11.5 / 19.5
Line Attenuation (Up/Down) [dB]: 13.0 / 20.0
SN Margin (Up/Down) [dB]: 25.0 / 11.5
Vendor ID (Local/Remote): TMMB / ALCB
My migration to plusnet (business 3) has only happened this morning, so maybe it will take time to increase?
Overall a very pleasant trouble-free migration though
Message 1 of 6
(3,304 Views)
5 REPLIES 5
Re: Upload speed
12-04-2010 4:06 PM
No it isn't.
But if you were on 448kbps with your previous provider the migration would probably have retained that and it will need a further action from Plusnet to upgrade you.
Message 2 of 6
(533 Views)
Re: Upload speed
12-04-2010 4:13 PM
thanks for your reply Oldjim, yes it was the same with my old provider, do i need to action a ticket or will someone in the know pick this up from here?
thanks again.
thanks again.
Message 3 of 6
(533 Views)
Re: Upload speed
12-04-2010 4:18 PM
Indeed, on checking this, this is a result of the type of migration that has been placed.
I have now submitted an order for you to correct this, which will complete overnight tonight. Your upstream should increase to 832kbps based on statistics.
Message 4 of 6
(533 Views)
Re: Upload speed
12-04-2010 4:24 PM
Excellent, thank you very much Phil, greatly appreciated
Message 5 of 6
(533 Views)
Re: Upload speed
13-04-2010 8:04 AM
Upload speed now at 832, thanks again Phil
Message 6 of 6
(533 Views)
